Farmall Tractors Discussion Board
Re: Re: Ignition Systems
Posted by Bob M on August 13, 1999 at 04:59:17 from (192.232.120.194):
In Reply to: Re: Ignition Systems posted by Paul Fox on August 13, 1999 at 04:03:11:
Well Paul - for claiming to not be an "expert" you seem to have this ignition stuff down pretty good!
A (minor) correction to battery vs magneto discussion however: Battery ignition throws a hotter spark at it's lowest speed. Thus battery ignition is generally preferred for easy starting. A mag's sparks however get hotter the faster it spins. Thus it has the advantage for high compression/high RPM engines.
At typical tractor engine speeds, a battery ignition is entirely satisfactory, and is cheaper and less fussy to maintain than a mag. Hence you don't see not a lot of mag-equipped tractors out there anymore.
Post a Followup
: Re: Re: Re: Ignition Systems
