Farmall Tractors Discussion Board
Re: 350 Farmall Runs, but misses - need help!
Posted by The Red. Smells like on August 13, 1999 at 07:07:16 from (206.246.187.2):
In Reply to: 350 Farmall Runs, but misses - need help! posted by Gill on August 13, 1999 at 05:17:10:
Gill, you might have a broken spring in your distributor. Since it gets worse as you speed up, the timing appears not to be advancing correctly. You will have to remove the breaker plate and you should beable to see if that is the culprit.
Post a Followup
: Re: Re: 350 Farmall Runs, but misses - need help!
