Re: Re: Re: sleeves falling out the top of 282 Diesel ?
Posted by Honkey on June 08, 2002 at 15:40:00 from (64.68.163.14):
In Reply to: Re: Re: sleeves falling out the top of 282 Diesel ? posted by Chris Brown on June 08, 2002 at 08:00:58:
Chris, If I was you, I would go to your local auto parts store and get some green machinist Loctite. Put it on the bottom 1/3 of the sleeves and put them in. I would get three new sleeves, and put the Loctite on them as well. Be sure to check sleeve protrusion before you apply the loctite. Also, try every sleeve in every hole. There will be one that will fit a little tighter than the rest in a really loose hole. If you take the head of any 560D you will find a cracked sleeve or two. In your case three. That's just the way they are. They will run just fine and have a cracked sleeve. I would closely examine and check the head and the block deck for warpage. I would bet that is why it is loosing antifreeze. If you have an early serial # 282, check for a crack in the rear of the head. Usually on the rear most head bolt hole. Mine was cracked there. From what I have been told, it is common on the early ones. If you ever have to get a different head, get one for a 656D, they have the big valves and are much better about not cracking. Good luck, Matthew in SD
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
