Re: Farmall carb overhaul problem
Posted by BIG JOHN on June 12, 2002 at 15:33:08 from (64.12.102.154):
In Reply to: Farmall carb overhaul problem posted by Brad Harper on June 12, 2002 at 15:03:19:
Sounds like you may have dirt in the neddle valve which is keeping the gas from flowing into the carb at full flow. This would cause the govener to surge because of the lack of fuel. Then when it is not running the dirt keeps the neddle valve from fully closing causing the over flow of fuel after some time passes.
Post A Followup
: Re: Re: Farmall carb overhaul problem
