Re: Re: Farmall carb overhaul problem
Posted by Brad Harper on June 12, 2002 at 17:07:01 from (67.232.227.87):
In Reply to: Re: Farmall carb overhaul problem posted by BIG JOHN on June 12, 2002 at 15:33:08:
Big John:
Thanks for the tip. I will open up the carb remove the floats and so I can clean the needle valve. By the way, when I drained the carb this morning I noticed lots of fine grit. I guess the sediment bowl and the fuel line filter could not keep it all out. So I will buy a new filter too.
Post A Followup
: Re: Re: Re: Farmall carb overhaul problem
