Farmall Tractors Discussion Board
Re: Re: Ignition Systems
Posted by TomH on August 13, 1999 at 17:04:30 from (206.99.145.203):
In Reply to: Re: Ignition Systems posted by Paul Fox on August 13, 1999 at 04:03:11:
Well, you kind of need an ignition switch if you ever want to turn the engine off ;o) although it really should be called a ground switch, since it just grounds the ignition circuit to short out the spark.
I always thought of a magneto as just a high voltage/low amperage generator that feeds directly to the distributor (instead of storing the energy in a battery).
Post a Followup
: Re: Re: Re: Ignition Systems
