farmall h oil pressure gauge
Posted by Bob on June 13, 2002 at 10:16:25 from (166.102.96.8):
The oil pressure gauge on my farmall h been sticking all the way up even after it is shut off. So I tried taking the line off the gauge and as soon as I loosened the line up about 2 turns the gauge went down, so I took it off and sprayed wd-40 in the gauge and the line and reassembled it, started the tractor and the gauge did the same thing. So I tried loosening the line a little bit until the gauge went down and then started it and oil poured out of the line, so I know it has pressure. Do you guys think my gauge is shot? I am trying to save it because it is the orginal! Any ideas would be appreciated! Thanks in advance! Bob
Post A Followup
: Re: farmall h oil pressure gauge
