Re: farmall h oil pressure gauge
Posted by ca on June 13, 2002 at 11:32:43 from (207.54.105.157):
In Reply to: farmall h oil pressure gauge posted by Bob on June 13, 2002 at 10:16:25:
If the gage is not leaking and is giving a proper reading it must be ok. Try another gage and see if it gives the same pressure readings. The gage pressure not going down untill you crack the feed line open. Tells me the pressure is not bleeding down in the engine block after you stop, Or did somebody but a check valve in the feed line "check". Dirt or forren material in the feed line mite act like a check valve, But it's not likely. This could cause a proplem if your running the engine and the oil pressure drops due to low oil level,plugged filter or oil pump quits etc, And the gage stays up you will think oil pressure is good. And then hear the engine knocking. Good luck and let us know
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
