Re: Nuts and bolts question
Posted by Just make darn sure... on June 13, 2002 at 18:59:22 from (198.81.17.29):
In Reply to: Nuts and bolts question posted by ScottyNY on June 12, 2002 at 14:16:35:
This isn't addressed so much to you Scotty as to the issue of grade 5 and 8 bolts in general. I just wanted to add that I would be mighty slow to make use of one of those grade 8 bolts unless there was some particular spec calling for it. If you use either grade, do yourself a favor and use some anti-thread seizing compound. I've seen more than one person regret that they were ever used when they encountered difficulty in removing one that had been frozen in place or had the head stripped. Drilling them out is nearly an impossible task.
Post A Followup
: Re: Re: Nuts and bolts question
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
