Stuck rings on H
Posted by Fred on June 13, 2002 at 19:25:59 from (64.12.104.154):
Last fall my Farmall H ran fine. This spring when I went to run it for awhile it ran poorly. A valve was stuck on no. 1 cyl with a bent push rod, no compression in nos. 1, 3 and 4 cyls. I suspect stuck rings. No. 2 cyl has 95 psi. I replaced the bent push rod and freed the valve. Anybody got any free advice or any home brew to free up stuck rings. Fred
Post A Followup
: Re: Stuck rings on H
