Re: Farmall Super C carb!!!!! HELP!!!
Posted by BIG JOHN on June 15, 2002 at 14:20:59 from (64.12.105.161):
In Reply to: Farmall Super C carb!!!!! HELP!!! posted by Cory Hubbard on June 15, 2002 at 14:05:27:
Sounds like a fuel flow problem to me. Open the plug at the bottom of the carb. You should have a continuious flow, let it run for several minutes to make sure it doesn't slow down. You can catch the fuel. If it slows down then that is the problem. Check everything from the gas tank to the carb. Don't for get the screen that is behind the inlet fiting on the carb (Zenith) not sure about Marvel. Good Luck
Post A Followup
: Re: Re: Farmall Super C carb!!!!! HELP!!!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
