M has no power under load
Posted by Dave Westlund on June 17, 2002 at 04:17:21 from (204.220.32.184):
I have a friend that has a M tractor. It is set up with a 12 volt system. The tractor wasn't running good when I got there. The points were burnt and the tractor would backfire. We went and purchased new points and router cap. Put them in and the tractor worked fine. I Did not drive it around. I got a call the next day and he said that it has no power at all, idles well, but no power to even climb a hill.
That could mean not enough gas getting to the carb or could the points be getting burnt because it is converted to 12 volt? It does have a resistor install before the coil. What else is there?
Please help!
Thanks
Post A Followup
: Re: M has no power under load
