farmall h carb?
Posted by Bob on June 18, 2002 at 16:38:00 from (166.102.96.95):
I have been having trouble with the carb on my farmall h. When you turn the gas on, after a moment gas starts running out the overflow on the carb. Also after tractor starts you have to hold the choke about half way on for it to keep running for a minute or so then it will run but kind of rough. Also when at idle smoke comes out the exhaust and when you accelerate from idle it smokes for a few seconds then quits while running at higher rpm. I tried adjusting the screws on the carb and the only one that seems to make a difference is the idle limiter screw. This is a newly rebuilt motor and carb. Does anyone have any ideas about what could be wrong with my carb? Sorry for the long post! Thanks! Bob
Post A Followup
: Re: farmall h carb?
