Re: super a oil pressure
Posted by Glenn(WV) on June 18, 2002 at 20:43:02 from (67.201.149.161):
In Reply to: super a oil pressure posted by ih_bug on June 18, 2002 at 19:52:48:
The C-123 in my Farmall 100 had a multigrade oil in it(my uncle did the last change). It would hit almost 30 psi cold and drop to 10-15 psi hot. I changed the oil to straight 30-weight, which is what is called for in the manual, and the cold pressure jumped to about 40psi; the hot pressure went up to about 18psi or so. If you're not running straight-weight oil, you might try it.
Post A Followup
: Re: Re: super a oil pressure
