1466 has pulsating lift arms while under load
Posted by Y. Canby on June 19, 2002 at 20:41:55 from (216.158.80.48):
Hello, I have a 1466 than when picking up an implement or large round bale the lift arms creep down an inch or two then jump back up. This only happens in the raised position with a fair weight on the hitch. It does it every few seconds and the problem is getting worse. I suspect a leaking valve somewhere or perhaps a seal ot of the main lifting cylinder. Any thoughts on this? Thank you all for your help!
Post A Followup
: Re: 1466 has pulsating lift arms while under load
