H tranny seal delima cont.
Posted by Ray A on June 24, 2002 at 18:29:58 from (66.64.31.98):
OK, I finally got the tapered bolts out of the drive yolk assembly. Now how do I get the yolk off so I can change the tranny drive seals. I undid the bolt holding on the yolk thinking it would slip off, but I seem to be sadly mistaken. Do I just use a crowbar to try to pry it off the shaft? Also how to get the lower drive stub off that is for the lift all drive so I can change that seal also? Are they pressed on? Sorry for taking up so much room on the board with what seems should be a simple task. Ray A
Post A Followup
: Re: H tranny seal delima cont.
