Re: OK I Will Plead My Ignorance 230 Hydraulics Wheres The Filler????
Posted by Steve L on June 27, 2002 at 07:42:28 from (161.11.4.10):
In Reply to: OK I Will Plead My Ignorance 230 Hydraulics Wheres The Filler???? posted by Drizler on June 27, 2002 at 06:46:18:
It sucks from a cast iron reservoir under the seat which has a valve body on it with a flow rate hand wheel knob and a isolation hand wheel knob. The Presure line from the pump goes into the valve. The transmission takes gear oil with a top fill plug by the shifter and a side site plug.
Post A Followup
: Re: Re: OK I Will Plead My Ignorance 230 Hydraulics Wheres The Filler????
