M liftall question
Posted by Tom W on June 27, 2002 at 12:33:17 from (166.94.9.204):
I have a 49 M with a loader and 3 point lift. I changed the liftall fluid last fall and put 6 quarts of 30W non detergent in. The loader and the 3 point worked fine until last month when I started using a post hole auger. After a few holes the the 3 point would not lift. I changed the oil in the lift all and it will works fine for about an hour, then it get weak. Is there any heaver oil I can use for the summer? It works fine until it get hot.
Post A Followup
: Re: M liftall question
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
