Re: M liftall question
Posted by john d on June 28, 2002 at 21:41:10 from (205.188.192.164):
In Reply to: M liftall question posted by Tom W on June 27, 2002 at 12:33:17:
SAE 30 non detergent IS the correct oil for the liftall units. Hytran or similar products will work, but not better than SAE 30. It would appear that the unit is getting worn, and when the oil heats up it loses enough pump pressure to cause the problem. You have a few choices...but none of them may appeal to you. 1) Rebuild the pump. Not a really bad job if you're mechanically inclined, but parts won't be cheap, and the pump is a beast to lower out of the tractor without help. It will almost certainly be heavier than you expect. DO NOT have your feet, hands, or (worse yet) your head under it when it comes loose! 2) Use a larger diameter cylinder on the 3pt hitch. A larger cylinder can lift the same load on less pressure. Another alternative would be to modify the hitch to take 2 cylinders for the same effect. 3) Explore the possibility of modifying the 3pt hitch to allow for the use of a longer-stroke cylinder which could be mounted in a position to lift with more mechanical advantage. If you have an 8"-stroke cylinder now, and you can weld on a bracket to allow for the same movement of the 3pt hitch with a 12"-stroke or longer cylinder, the old pump may still lift the load. 4) Use SAE 40 oil. This will help a little, as the oil won't thin as much when warm. I actually used some 20W50 in a Super M lift-all for a while that was having similar difficulties. (And no, it did not seem to have any foaming difficulties with this type of oil.) 5) Price the possibility of converting to a live-hydraulic system instead of rebuilding the old lift-all unit. Cost will be more, but the conversion will result in a more versatile tractor with increased value.
Home
| Forums
Today's Featured Article -
Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
