Re: Re: Re: Re: Re: OK I Will Plead My Ignorance 230 Hydraulics Wheres The Filler????
Posted by David Zeman on June 28, 2002 at 10:31:58 from (205.188.201.148):
In Reply to: Re: Re: Re: Re: OK I Will Plead My Ignorance 230 Hydraulics Wheres The Filler???? posted by Drizler on June 28, 2002 at 07:15:06:
Drizler, This may sound weird but if you are adding fluid to the unit try removing one of the mounting bolts from the control unit to the drive tube. They are open into the reservoir and should make it somewhat easier to add oil than trying to go thru the pipe plugs on the top of control unit. That front left hand bolt is right next to the fill plug on my tractor. Hope this will help, Dave
Post A Followup
: Re: Re: Re: Re: Re: Re: OK I Will Plead My Ignorance 230 Hydraulics Wheres The Filler????
