Re: Farmall 706 PTO won't rotate under a load
Posted by the tractor vet on June 28, 2002 at 18:59:28 from (216.196.13.86):
In Reply to: Farmall 706 PTO won't rotate under a load posted by JH on June 27, 2002 at 11:39:20:
You could have sheared the tinny littel pin on the spool valve as this is sorta common . The valve removes from the bottom but you must remove the sway bar linkage bracket to remove the spool valve if this is the problem . To see if you need to go through all this first remove the linkage on top of the valve but it will help if you count the turns of the square nut as this sets the PTO pressure and it takes a special fitting to attach a gauge to and the pressure should be around 210 to 250 PSI myself i like the higher setting as this way i know the clutches will not slip under heavy load. remove the big nut and see if the valve will come out the top and if it does then the littel pin has sheered and you must start removing stuff as it should not come out the top and you only have half the valve the rest will have to come out the bottom when it is all back to a one pigce then it goes in from the bottom. Then the pressure must be set to the above settings by turning the the valve stem into the nut there is a small hole in the stem and a small punch will do the job.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
