Re: Re: Re: Farmall H - PTO problem
Posted by Jeff on June 29, 2002 at 18:38:43 from (12.2.88.129):
In Reply to: Re: Re: Farmall H - PTO problem posted by stephen on June 29, 2002 at 13:16:43:
Stephen, This first part is going to be hard for me to describe, so please bear with me: if you have the hydraulic pump, it will appear, from the side of the tractor, like a "triangle" with a hole at the bottom point; this "triangle" is on the bottom side of the chassis (the section under the gas tank). There might be a semi-flat plate on the bottom that's held in with two bolts just behind the pump; remove it and you'll see a removable shaft that powers the hydraulic pump (this connects to the "bushing" of the countershaft I previously described) and the engine-to-transmission shaft above that (coupled together with four bolts). If you have the pump, there will only be about 6 to 8 inches of space; you'll see four bolts (9/16" I think) holding in the pump. Remove the countershaft-to-pump shaft and the four pump bolts and the pump will come out the bottom; BE CAREFUL because the pump is very heavy - use two people if possible. Also remove any of the 1/2" hydraulic piping on the outlets, or the pump won't come out (there could be up to three of these). In this cavity, in the upper rear portion, is the hub that connects the engine to the transmission (I think it has six or nine 9/16" bolts) - remove this and the front part of the sliding gear shaft will be free. Remove the three bolts you mentioned that are on the other end, and the shaft should come out. The countershaft might be harder: remove the "bushing" for the front part, and remove the snap ring for the back part; it should come out. You don't need to remove the reversing gear. Do everything backwards to put it back together, but do these two things: 1. Make sure you move the sliding gears in their proper position so they mate with the gear forks. 2. Be very careful and slow when you put the engine-to-transmission hub back on, because if you did what I did, you'll accidentally destroy the roller bearing that connects the shaft to the hub; make sure they line up and go in together easily (also pre-oil this roller bearing if you think of it). They don't make a transmission cover gasket, so you'll have to use a sealant like silicone gasket goop or form-a-gasket.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
