Re: Re: Farmall H - PTO problem
Posted by stephen on June 29, 2002 at 13:16:43 from (152.163.205.71):
In Reply to: Re: Farmall H - PTO problem posted by Jeff on June 28, 2002 at 20:47:39:
Jeff,
Thanks for the help. I ordered the parts manual, but it won't be here for a few days. I tore into it anyway, and have gotten as far as the sliding gear shaft. I'm not sure what to do at this point. There are three bolts around the rear bearing, I assume they have to come out. What about the front? Is this where the hyd. pump has to come out? Where is the pump located and how do you get to it? I'm guessing you get at it from the bottom? Any more details you can give me would be appreciated.
Post A Followup
: Re: Re: Re: Farmall H - PTO problem
