Re: Farmall H Countershaft Nut ....Fun!!!! Bearings too expensive!
Posted by farmallflogger on July 01, 2002 at 14:02:11 from (24.74.24.247):
In Reply to: Farmall H Countershaft Nut ....Fun!!!! Bearings too expensive! posted by Scott L. Swanson on July 01, 2002 at 10:40:20:
Thought I was being smart and bought a "replacement" bearing for the mainshaft pilot bearing in my M. The replacement was a standard one piece ball instead of the original 2 piece straight roller. Anyway I pull this M and the bearing lasted less than a year. When it failed it took a tooth off the input driving shaft. Believe me that $50.00 bearing is a bargain. I'll think you'll find case/ih gaskets are reasonable too. By the way the oem mainshaft pilot bearing is fine after several years of pulling.
Post A Followup
: Re: Re: Farmall H Countershaft Nut ....Fun!!!! Bearings too expensive!
