Re: where is temp sensor on 460?
Posted by Tony 630 on July 03, 2002 at 16:10:22 from (165.247.68.21):
In Reply to: where is temp sensor on 460? posted by mike johnson on July 03, 2002 at 09:03:00:
Mike,
Simple question simple answer.
Assuming it gas, go to exhaust/intake side of engine and you should find it between valve cover and exhaust manifold in between two bolts....Should take a 3/4" 6 point socket. Will probably be stuck; lightly heat cylinder head around threads. Remove.
Tony
Post A Followup
: Re: Re: where is temp sensor on 460?
