Farmall Tractors Discussion Board
Farmall 404 transmission grinds when shifting.
Posted by T. on August 16, 1999 at 11:23:48 from (209.244.91.66):
Scenarios:
I push in the clutch, start the tractor at low idle, shift into any gears and it does NOT grind.
I let out the clutch with tractor in motion. I reduce speed and brake to stop. I then push in clutch, shift "quickly" with tractor completely stopped and it does NOT grind.
Tractor DOES grind when:
I push in the clutch, start the tractor and increase engine speed, shift into any gears.
I let out the clutch with tractor in motion. I reduce speed and brake to stop. I then push in clutch. I let out clutch. Wait a few seconds and then push in clutch and shift "quickly" with tractor completely stopped.
Background:
I have just replaced with new clutch disk, pressure plate, throw-out bearing, clutch shaft bushing, and pilot bushing.
Pilot bushing was extremely worn, and I thought that this may have been causing grinding.
What else could it be?
Thanks,
T.
Post a Followup
: Re: Farmall 404 transmission grinds when shifting.
