Re: Cub LoBoy 154
Posted by Farmer Bob on July 07, 2002 at 12:20:42 from (66.152.73.123):
In Reply to: Cub LoBoy 154 posted by Farmall Don on July 07, 2002 at 11:45:46:
Sure sounds like you got some sediment into the carb passages when you ran it out of gas. It don't take much. Start at the sediment bowl and work toward the carb. Clean everything again, and check the screen attached to the fitting that screws into the carb where the fuel line attaches. Disassemble the carb and use compressed air to blow out all passages. You may not even see the culprit that's causing the problem. Hope it works. Reset the carb float to spec. and pray.//FB
Post A Followup
: Re: Re: Cub LoBoy 154
