Re: Farmall A motor locks up?
Posted by Hugh MacKay on July 08, 2002 at 02:46:10 from (216.208.58.141):
In Reply to: Farmall A motor locks up? posted by bill on July 08, 2002 at 02:14:02:
Something is loose somewhere and comming out of place. I would try removing starter, could be faulty starter drive, is a easy one to check. If that is fine next place I would ckeck is governor and this will also give you a peak at timing gears. Check the easy items first, may save yourself a lot of work. Items inside engine don't usually free up. Don't over look clutch and presure plate. I am not much help, however on a couple of ocasions I have overlooked the easy one's and done a lot of work for nothing.
Post A Followup
: Re: Re: Farmall A motor locks up?
