Re: 444 diesel
Posted by David on July 10, 2002 at 05:21:37 from (205.215.216.200):
In Reply to: 444 diesel posted by bg on July 09, 2002 at 16:33:47:
bg, can you tell if it is the PTO or the drive clutch chattering? Has the clutch been replaced recently? I have a 68 44 diesel also. I have never had a problem with the clutch, but I remember seeing in my manual that there is a set procedure for setting it up when you install it. Maybe it was never set up correctly.
Post A Followup
: Re: Re: 444 diesel
