Re: Re: Farmall M cluthh replacemett-HELP!
Posted by Mike House on July 13, 2002 at 19:42:32 from (216.221.104.248):
In Reply to: Re: Farmall M cluthh replacemett-HELP! posted by Alton on July 13, 2002 at 19:22:10:
All the parts were the same and when I moved it this morning before I split it apart, the clutch worked. The reason I replaced it today is that it was slipping under load. When I first put it back together after the replacement, I hadn't adjusted anything yet, but that's when I checked by looking up through the belly-pump tank cavity as my wife pushed in the clutch and found this problem. Mike
Post A Followup
: Re: Re: Re: Farmall M cluthh replacemett-HELP!
