W-6 shift lever pivot pin trouble
Posted by PoppinJohn720 on July 14, 2002 at 21:19:30 from (63.208.45.153):
Just got my W-6 back home after plowing about 35 acres of groung that was harder than h@##. I noticed that the shift lever seems loose now and when I looked closer I noticed that the pivot in appears to have broken because a piece of it has worked its way out to the right and only thing that kept it from falling out is the steering gearbox. I can push it back in very easy then move the shifter a little bit and its back out. Can I replace this pin or will I have to pull the whole top of the tranny off? Where can I get a new pivot pin? Thanks for the help!
Post A Followup
: Re: W-6 shift lever pivot pin trouble
