6v Generator Voltage?
Posted by Mitch on July 15, 2002 at 04:00:40 from (199.197.135.1):
I have not messed with 6v systems much but I assume that the generator should be putting out somewhere around 7-8 volts when running. I am working on a Super C and it is showing a very slight charge on the gauge while running but the volt meter only shows about 6.3 volts while running. The regulator appears to be working fine as I can see the contacts closing when I start it. It has a new battery but the cranking power does not stay up where it should after running it. I just wanted to get some more info. before I take the generator in for a rework. Thanks much.
Post A Followup
: Re: 6v Generator Voltage?
