Re: 6v Generator Voltage?
Posted by Bob M on July 15, 2002 at 04:40:30 from (165.170.128.66):
In Reply to: 6v Generator Voltage? posted by Mitch on July 15, 2002 at 04:00:40:
Mitch - Temporarily connect the generator "F" terminal to a good ground, then run the motor at full speed and check the ammeter. If it shows 15 or so amps , the regulator is bad. If it still only a slight charge, problem's with the generator.
Incidentally system voltage should be about 7.0 - 7.4 volts while charging...
Post A Followup
: Re: Re: 6v Generator Voltage?
