Farmall Tractors Discussion Board
Re: Update on 350 runs but misses - still need help!
Posted by ltf in nc on August 16, 1999 at 20:17:45 from (206.228.213.58):
In Reply to: Update on 350 runs but misses - still need help! posted by Gill on August 16, 1999 at 18:45:33:
Remote chance but not out of the question, it could have a broken intake valve spring. If the exhaust valve was sticking the compression would be off. I tend to think it is a electrical problem such as a cracked dist. cap, plug, or a bad plug wire. Look at all the plugs again and see if you can locate one that is different in appearance than the rest. It will be a fault with that cylinder.
Post a Followup
: Re: Re: Update on 350 runs but misses - still need help!
