Farmall H poofing sound in exhaust?
Posted by Bob on July 19, 2002 at 09:33:56 from (166.102.96.57):
I recently rebuilt the motor in my H. Rebuilt the carb too. When it is idling it has a slight poofing sound from the exhaust. Also after being at idle then pulling the throttle up it has a slight puff of smoke out the exhaust then clears up. I was thinking maybe a carb adjust but the only screw that seems to do anything is the idle stop screw. The other two can be turned all the way in or out and don't seem to make a difference. I did retorque the head and readjust the valves. New spark plugs gap set at .025. The sound doesn't seem to effect the performance but I want this thing to run as good as possible after all the work I put into it. Any help would be appreciated! Thanks Bob
Post A Followup
: Re: Farmall H poofing sound in exhaust?
