Re: 706 Range trans jumps out of gear
Posted by the tractor vet on July 20, 2002 at 07:12:36 from (216.196.13.63):
In Reply to: 706 Range trans jumps out of gear posted by DRGreen on July 19, 2002 at 18:22:44:
The problem is that the spring and rolleron the shifter cam has broken and that is sorta and easy fix , you will need a top cover gskt. and a side plate gskt ., one or two rollers and a spring . It helps if you have someone help ya , first remove the deck plate unhook your linkage and remove any hdy. lines that are in the way unhook the park linkage best to put the tractor on a lean to the right , like put a 6x6 under the left rear tire then remove the side plate on the left side of the rear houseing you will lose about one gal of hytran this will give you axcess to the reverse shifting fork this is where a second set of hands come in then remove the bolts from the top cover use a stiff bladed putty knife to break lose the top cover ( if you have a spring loaded park lock you must make sure that you have it in the out of park posisionand blocked up with a 3/4 inch spacer i myself use a 1/2 inch nut up on end) if it is the old style don't worry about it just pry evenly up and have you buddy watch the rev shift fork and grab it as it falls out this is a good time to check it for ware pay close attenshion to the rev shifter shaft and key way as it may be wore and you may lose the key if the key is not tight in the shaft then this make for a real had to find rev. this is the time to replaceany woren parts also replace all the headed pins in the shift linkage . I have done many of these.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
