706 Range trans jumps out of gear
Posted by DRGreen on July 19, 2002 at 18:22:44 from (152.163.197.188):
Just bought the tractor - jumps out of High and Low range when on slight downhill grade. I replaced bushing in Range shift lever on console which removed the slop there, but the problem still exists. The rest of the linkage, even the short "cub tie rod end" linkage is pretty tight with very little movement of slop. The lower linkage rod at the bottom shows little if any wear. All in all, the shift linkage seems good to me with very little slop, even with all these various potential places for wear. Still, "finding" low and high range feels sloppy and vague - you need to ease out on the clutch to see if it is in a Range gear or not, especially with low without the shroud to tell you were low ought to be. Going from neutral to low it is very easy to pass low completely and when it is in low gear, there is alot of movement in the shift lever. High must be pushed completely forward against the shroud covering the shift levers (and held there on a downhill grade). After pulling the platform to cleanup 40 years of crud, I found that most of the slop seems to be inside the trans case itself. When disconnected from the shift linkage, there is alot of slop in the lever coming out the top of the trans. Previous owner forgot to send the owners manual along ('course it wasn't supposed to jump out of gear either...) It's supposed to be mailed but hasn't gotten here yet and the local IH dealer didn't have one. It seems to me that the trouble is going to be found under the trans cover. I'm going to get a manual one place or the other but would kind of like to get started on this now if I can. The archives mention shift forks being bent or out of adjustment, wear in the shaft or linkage, etc. If I remove the top cover, are the shift forks and it's shaft and linkage connected to the cover - should it lift off pretty easily or is there something under that cover I should know about before I get started? The archives were real helpful but I'm new to IH's and your help would be appreciated - thanks!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
