Re: Re: 706 Range trans jumps out of gear
Posted by the tractor vet on July 20, 2002 at 18:30:41 from (216.196.13.70):
In Reply to: Re: 706 Range trans jumps out of gear posted by Hey Thanks! and another quick question. on July 20, 2002 at 10:00:30:
The shifter shaft is welded from the factory , you may find that the roll pin that holds the shifter cam on may be sheared and my be the keyway is wore if this is the case then replace the shifter and also check the detent plate on the cam sometimes these will ware real bad and must be replaced , you can replace just the plate and not but the cam assy. Just look everything over real good and replace what is needed.
Post A Followup
: Re: Re: Re: 706 Range trans jumps out of gear
