Re: Re: Re: wiring problem still
Posted by The Red on July 23, 2002 at 11:11:59 from (206.246.187.2):
In Reply to: Re: Re: wiring problem still posted by dave on July 23, 2002 at 10:44:09:
Dave I will dig up a picture and email you after I get home.
The screw at the bottom of the fuse bracket is for the lights. You can have the coil wire going from that post or the ampmeter post to the coil switch. It doesn't matter.
Sounds like you have the yellow wire in the correct position. Yep the cover is part of the grounding.
Post A Followup
: Re: Re: Re: Re: wiring problem still
