Re: Re: wiring problem still
Posted by dave on July 23, 2002 at 10:44:09 from (208.32.170.140):
In Reply to: Re: wiring problem still posted by The Red on July 23, 2002 at 09:43:32:
what is the thing that hangs down from the switch?, that is what the yellow wire is attached to. also on the bottem of the fuse is a connection, what is that? that is what my on off switch is attached to along with a short wire going to the ammeter. do you know of a wiring diagram that fits this tractor? i think i wired it wrong based off of three different diagrams that i have at home. is it true that the light switch cover grounds the system? thanks dave
Post A Followup
: Re: Re: Re: wiring problem still
