Re: 1953 sm (grounding)
Posted by Bob M on July 23, 2002 at 17:38:24 from (24.169.120.138):
In Reply to: 1953 sm (grounding) posted by bud bareenie on July 23, 2002 at 13:28:15:
Bud - I had grounding problems with my '53 SM too. Only my problems resulted in several "no start" situations, and once with fire when a hydraulic hose ignited near the live pump (battery box had rust between it and the deck plate, so the battery was grounding thru the hyd hose reinforcing wire). Solution was to buy a longer battery ground cable and bolt the end of the cable directly to one of the starter mounting bolts. Haven't had a problem since!!
I had similar starting problems with the diesel in my old KW truck - running the heavy ground cable direct to the starter cured that one too.
Post A Followup
: Re: Re: 1953 sm (grounding)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
