Re: H generator charging ?'s
Posted by Bob M on July 24, 2002 at 20:05:18 from (24.169.120.138):
In Reply to: H generator charging ?'s posted by Mike ISW on July 24, 2002 at 14:21:08:
Mike - With the motor running at full RPM you should see about 3 - 5 amps charge with the switch set on "L", and between 10 - 15 amps on "H". Cutout points should be closed whenever the motor is running above about 1/4 throttle, regardless of switch position.
Presuming the generator and wiring is OK, possible causes for your problem: 1 - Bad ground at the ammeter box (i.e. between the box and the steering stantion, or between the stantion and the tranny deck plate). 2 - Bad ground between the ammeter box cover and the box. 3 - Bad light switch.
Hope this helps!
Post A Followup
: Re: Re: H generator charging ?'s
