Farmall Tractors Discussion Board
Re: Update on 350 runs but misses - still need help!
Posted by Pappy on August 17, 1999 at 16:48:33 from (205.188.192.57):
In Reply to: Update on 350 runs but misses - still need help! posted by Gill on August 16, 1999 at 18:45:33:
If you have 140 PSI on each cylinder, forget about bad valves. I had an H last week that would run perfectly for the first ten seconds after it was started, then start to miss on # 3 cylinder. After it warmed up, I sprayed carburetor cleaner under the intake manifold around the #3 and #4 port and it started running perfectly. Sealed the leak and readjusted the carburetor and it runs like was made last month.
Post a Followup
: Re: Re: Update on 350 runs but misses - still need help!
