Farmall H Tranny Swap Questions!
Posted by Scott L. Swanson on July 29, 2002 at 05:17:02 from (209.180.31.9):
I am ready to put the transmission/Final Drive back into my Farmall H. Is there an
accepted order to reinstalling these gears and what ever? I was thinking the lower
transmission gear shaft and gears first, idler shaft/gears second, differential gearset and brake
stuff next, and drive pinion/upper transmission gears (sliding gears) last.
Does this sound right?
Also, where do I find new shims? Do they still make them?
I yanked the entire tranny/diff. out of one tractor and am putting it into another.
Will I need more shims? What area needs to be tightened with the shims?
What else should I look for with a complete tranny swap?
Thanks for the advice. You guys are great!
Scott
Post A Followup
: Re: Farmall H Tranny Swap Questions!
