Farmall Tractors Discussion Board
Re: Re: what weight oil do I use F-20
Posted by Farmall Gray on August 17, 1999 at 17:05:37 from (152.163.204.74):
In Reply to: Re: what weight oil do I use F-20 posted by The Red on August 17, 1999 at 04:47:22:
The owners manual calls for SAE 160 in the trans,
rearend and final drives. I have not been able to
find 160 but have found SAE140. Unless you have
replaced all of the seals, they will probably leak
with 90W. They may even leak if you have replaced them. Most of the seals are felt and they don't
seal as well as modern rubber seals. I would recommend you go with 140 unless you are going to
run it in the winter.
Post a Followup
: Re: Re: Re: what weight oil do I use F-20
