Farmall Tractors Discussion Board
Re: what weight oil do I use F-20
Posted by The Red on August 17, 1999 at 04:47:22 from (12.75.197.125):
In Reply to: what weight oil do I use F-20 posted by Randy on August 17, 1999 at 04:36:25:
8 quarts SAE 30 in the engine. 8 gallons 90W in the rear end/transmission. 1/2 gallon 90W in each axle extender assembly. SAE 30 in the air bath cleaner. Should be a full line on it.
If your timing lever is correctly positioned, put it in the 2 o'clock position for start. I usually do one full crank on full choke, then back the choke to 1/2. Mine usually fires on the third crank. After it starts, be ready to milk the choke until it starts warming up.
Post a Followup
: Re: Re: what weight oil do I use F-20
