Re: Delco 10SI Alternator -- shaft size
Posted by Craig on July 30, 2002 at 19:50:13 from (209.131.236.48):
In Reply to: Delco 10SI Alternator -- shaft size posted by Don LC on July 29, 2002 at 18:23:12:
I think the other guys are right that it is a 17 mm bore in the pulley. Go to your local alternator/starter repair shop. They usually have a selection of pulleys for those in stock. Ohterwise they can order one. When I 've used those alternators on my tractors I look for a plulley machined from solid steel, not the stamped steel ones. Then I mounted them on a arbor in the lathe and made it into my choice of diameter and widened the groove to match the original tractor belt width. Oh yea, Delco Remy used to have blank pulleys availalbe. You have to make your own groove in them with a lathe.
Post A Followup
: Re: Re: Delco 10SI Alternator -- shaft size
