1942 Farmall H serial#93521
Posted by Jeanne on July 31, 2002 at 11:11:29 from (208.231.155.11):
we are overhauling this tractor and need the following specs: Main bearing Clearance, connecting Rod bearing Clearance, Piston Ring Side Clearance-second ring. This and anyother specs or information would be greatly appreciated. Thank You
Post A Followup
: Re: 1942 Farmall H serial#93521
