Re: 1942 Farmall H serial#93521
Posted by Bill Hires on August 01, 2002 at 07:03:08 from (128.206.231.155):
In Reply to: 1942 Farmall H serial#93521 posted by Jeanne on July 31, 2002 at 11:11:29:
Main bearing, diameter clearance 2-3, rod bearing diameter clearance 2-3, piston skirt clearance 2-4, crankshaft end play 4-8, camshaft bearing clearance 1.5- 3.5, these are thousands of an inch mreasaurements. Main bearing torque 75, rod bearing torque 40, head bolt torque 70. Reject pistons and sleeves if a spring pull of 11-15 lbs. will withdraw a 1/2" wide feeler gage 0.0025 " thick. New pistons in new sleeves 4-6 lbs. pull on a feeler size of 1/2" wide x 0.0015 thick. These are from an I&T IH shop manual.
Post A Followup
: Re: Re: 1942 Farmall H serial#93521
