Re: Re: Re: Re: 300 Utility Hydraulics: Hot Oil and Chatter
Posted by Kilian on August 07, 2002 at 09:51:40 from (207.230.193.30):
In Reply to: Re: Re: Re: 300 Utility Hydraulics: Hot Oil and Chatter posted by dick on August 07, 2002 at 09:16:54:
Thanks for the reply. When going over the Flow/Control valve, is it worth putting in the service pack offered by Case/IH ($144--includes gasket [3], seal [4], piston [5], and seat [6]), or should a good cleaning of the orifice and passageways do the trick?
Also, with regard to the cross check valve, the hitch does bleed down when under load. Would it be a situation of cleaning inside once again, or would the O-ring (3), and possibly the spring (6) and ball (5) need replacement?
Thanks again for your help.
Post A Followup
: Re: Re: Re: Re: Re: 300 Utility Hydraulics: Hot Oil and Chatter
